vcCustomDof
vcCustomDof
Parent: vcDof
| Joint | vcMatrixExpressionProperty | R | Gets the expression property that, when evaluated, returns the joint definition of the joint. VALUE can be used to reference the current value of the joint, for example "VALUE+10". |
| Pivot | vcMatrixExpressionProperty | R | Gets the expression property that, when evaluated, returns the pivot point definition of the joint. VALUE can be used to reference the current value of the joint, for example "VALUE+10". |
